2026-10-14 18:37:22
179
⛩️ Chinese Pavilion Drawers (100% Support-Free)
@TheGulzar3D_2711681
⛩️ Imperial Pavilion Drawer Set: The Support-Free Chinese Heirloom
Bring the timeless elegance of traditional Chinese architecture to your desktop with this meticulously engineered, multi-part organizer. Whether you use it as a premium jewelry box, a desktop organizer, or a statement piece, this model is designed to be as satisfying to print as it is to display.
Designed from the ground up for FDM perfection, this model takes full advantage of modern multi-color systems while completely eliminating the need for messy supports.
✨ Key Features & Engineering Marvels
  • 🚫 100% Support-Free Architecture: Every component has been logically separated to print flat on your build plate. From the intricate lattice doors to the main carcass, you will get factory-smooth finishes without touching a single piece of support material.
  • 🎨 Multi-Color Mastery: The ornate drawer fronts utilize a brilliant "Snap-On Faceplate" design. Printed completely flat on their backs, these 2mm thick multi-color panels drop perfectly into a custom 45-degree chamfered pocket on the drawer boxes.
  • 🧩 The "Iceberg" Labyrinth Lock: Say goodbye to fragile, snapping drawer pulls! The hardware features a hidden diamond-shaped shaft that allows the drawer holes to print natively without supports.
  • 🔗 Carabiner-Style Snap Rings: The beautiful 19mm ring pulls feature a precise 2mm gap cut at a 45-degree diagonal angle. This acts as a mechanical puzzle lock—sliding on effortlessly during assembly, but mathematically impossible to pull off accidentally during daily use!
  • 🏛️ Modular Balcony & Roof: The upper pavilion features drop-in pillars (printed horizontally for unbreakable layer strength) and a separate roof designed for flawless overhanging eaves.
📐 Dimensions & Specifications
  • Overall Footprint: 251.5 mm (W) x 170.2 mm (D) x 281 mm (H)
  • Printer Compatibility: Easily fits on standard 260x260mm beds.
  • Assembly: Parts feature carefully calculated tolerances (0.15mm to 0.2mm) for a snug, satisfying fit. A few drops of CA glue (superglue) will lock everything permanently in place.
🧵 Recommended Filaments for the "Heirloom" Look
To achieve the authentic, premium wooden aesthetic shown in the hero images, we highly recommend using Matte PLA for the body and Silk PLA for the hardware accents:
  • Main Carcass & Roof: Walnut Brown Matte PLA (grounds the piece and beautifully mimics aged wood).
  • Pillars & Faceplates: Cinnabar Red Matte PLA (a traditional, muted brick red).
  • Lattice & Hardware: Antique Gold Silk PLA (provides a soft, realistic metallic reflection for the ornate details).
⚙️ Printing Settings
  • Support: None required. All parts (carcass, drawers, faceplates, hardware, and roof) print 100% support-free.
  • Placement: Print the Faceplates, Lattice Doors, and Hardware completely flat on their backs. Print the Pillars laying horizontally on the bed. Print the Carcass, Drawers, and Roof right-side-up.
  • Layer Height: 0.2mm (Essential for balancing print speed and capturing the support-free 45-degree chamfers cleanly ).
  • Wall Loops: 3 to 4 loops (Crucial for giving the drawer carcass a premium, heavy feel and ensuring the chamfers print perfectly solid ).
  • Infill: 15% (Gyroid or Cubic recommended to prevent internal stresses from warping the large boxes ).
  • Material: Matte PLA & Silk PLA (Walnut Brown and Cinnabar Red Matte PLA for the architecture, Antique Gold Silk PLA for the hardware and lattice ). Note: Increase your purge volumes when transitioning from Silk back to Matte to prevent a glittery residue.
  • Speed: Slow down outer wall speed to 50 mm/s for the Ring and Keyed Plug (Essential for precise 0.15mm tolerances on the 45-degree puzzle lock ).
If you print this model, please share your makes and different color combinations (like the Emerald Jade variant) in the comments!
support free
hardware
ams
traditional design
homedecor
storagebox
organizer
chinesearchitecture
cfs
jewelrybox
modulardesign
desktop organizer
nosupports
snapfit
3dprinted furniture
multicolor
deskaccessories
asian decor
pavilion
heirloom
