2026-01-18 16:55:02
24.6k
2.2k
多功能桌面整理架(Stackable storage box)
@David007_2386050
设计理念:
这是我设计的一款桌面整理系统,包含大收纳盒、小收纳盒、抽屉和洞洞板。可根据需求灵活组装,满足对桌面的整理与归纳,合理规划桌面的每一寸面积。其可堆叠设计,可以满足更多收纳 需求,侧边洞洞板设计,能更好利用侧面空闲面积,达到最大化合理利用。
This is a modular desktop organization system I designed, featuring large and small storage boxes, drawers, and a pegboard. It offers flexible assembly to meet your specific organizational needs, helping you optimize every inch of your desk space. The stackable design accommodates growing storage requirements, while the side-mounted pegboard makes excellent use of otherwise idle side space, achieving maximum space efficiency.
模型尺寸:
  • 小抽屉外形尺寸:100x160x50,单位毫米;(里面设有隔板,可隔成4小格)
  • Small Drawer Dimensions: 100x160x50mm (Internal divider included, splits into 4 compartments);
  • 小收纳盒外形尺寸:100x160x50,单位毫米;
  • Small Storage Box Dimensions: 100x160x50mm;
  • 大收纳盒外形尺寸:210x160x50,单位毫米;
  • Large Storage Box Dimensions: 210x160x50mm;
  • 洞洞板尺寸:160x210x15,单位毫米;(有23个孔洞,适配宜家洞洞板配件);
  • Pegboard Dimensions: 160x210x15mm (Features 23 holes and is compatible with IKEA pegboard accessories).
注意事项:
  • 打印前做好耗材烘干处理,清洁打印板子;
  • Dry the filament and clean the print bed before printing.
  • 打印配置文件是只有单个零件,需根据自己的需求自行增加对应的零件数量;
  • The print profile contains only a single part. Please manually adjust the quantity according to your needs.
  • 为了保证安装后不晃动,孔洞间隙比较小,所以安装的时候需用力卡进去,同时需注意安全,避免手被刮到;
  • To ensure a wobble-free fit, the holes have minimal clearance. Firm pressure is required to snap the pieces together. Please exercise caution to avoid scratching your hands during assembly.
收纳盒
整理架
桌面整理
洞洞板
抽屉
桌面整理系统
Stackable organizer
Stackable shelf
PDF
组合说明1.pdf
4.22MB
