2024-11-09 16:38:55
3.6k
365
模块化螺丝收纳盒Modular screw storage box
@mbus2008_1641049
相信你也有很多螺丝不易翻找的烦恼,当你找不到合适的螺丝收纳盒的时候,可以尝试下这款模块化组合的收纳盒。
标准盒子内部空间大小为71*46*42mm,加大盒子内部空间大小为71*102*42mm;
每个盒子可以分为上下两层,以放置较小的螺丝或者零件;
标准盒子的大小可以放入4颗18650电池;
每个盒子前面可以装入打印版标签,以方便区分收纳物品,也可以使用手写标签;
每个小盒子组合后配合紧密,并设计有限位;
另外设计有提手可以方便移动收纳盒。
I believe you also have a lot of troubles that screws are not easy to find, when you can't find a suitable screw storage box, you can try this modular combination of storage boxes.
The size of the internal space of the standard box is 71*46*42mm, and the size of the internal space of the enlarged box is 71*102*42mm;
Each box can be divided into two layers, upper and lower, to place smaller screws or parts;
The size of the standard box can fit 4 18650 batteries;
A printed label can be placed on the front of each box to make it easy to distinguish the stored items, or a handwritten label can be used;
Each small box is tightly matched after combination, and the design is limited;
In addition, it is designed with a handle to make it easy to move the storage box.
所有打印件无需支撑,材料可选PLA、PETG或者ABS;
需要五金:
标准盒子5*2mm磁铁*3;加大盒子5*2mm磁铁*4
提手需要4颗最短M4*10最长M4*16的CM超薄扁平C头内六角螺丝,如下图所示
All prints do not need to be supported, and the material can be PLA, PETG or ABS;
Hardware required:
Standard case 5*2mm magnet*3, enlarge case 5*2mm magnet*4
The handle requires 4 CM ultra-thin flat C-head hexagon screws with the shortest M4*10 and longest M4*16, as shown in the figure below
收纳
螺丝
模块
Modular
screw
storage
box
盒子
盒
