2026-08-01 11:53:36
972
52
波音 747
@TianMenProgram_3678690
Boeing 747
打印技巧:
打印板:使用纹理PEI板。
耗材:PLA
层高:0.2毫米
外壁环数:2
加速度:将所有加速度设置为1000毫米/秒²或更低。
重要提示:
由于材料收缩和打印公差,可能需要进行一些打磨和胶合。组装零件时请施加均匀的压力。
打印前,请彻底清洁PEI打印板,以确保良好的附着力,并确保您的耗材干燥。
特别感谢所有关注、点赞、下载和支持的朋友们!
Single cockpit, movable wings and canopy, glue required for assembly.
placed and taken out.
Printing Tips:
Print Bed: Use a textured PEI sheet.
Material: PLA
Layer Height: 0.2mm
Outer Wall Count: 2
Acceleration: Set all acceleration values to 1000 mm/s² or lower.
Important Notes:
Some sanding and gluing may be required due to material shrinkage and printing tolerances. Apply even pressure when assembling parts.
Before printing, thoroughly clean the PEI print bed to ensure good adhesion, and ensure your material is dry.
Special thanks to all friends for your attention, likes, downloads, and support!
Boeing 747
天门计划
客机
飞机
