2026-09-07 09:48:35
357
17
烈马Ⅲ火星车(Wild Horse‑3 Mars rover)
@David007_2386050
星穹联合体|探索署制式勘探载具 —— 烈马 3 号火星车
哑光深空蓝机甲车体,加高全域越野底盘,纯电四驱驱动适配火星复杂地貌。前置攻坚推铲清障采样,宽幅深纹越野轮胎无惧砾石浮土,双层导流尾翼集成星际通讯阵列,奔赴红色荒原,踏遍未知火星疆域。
模型尺寸:168x96x63,单位毫米。
注意事项:
  • 打印前请清洁打印板;
  • 模型采用拼装组合,原则上不需要胶水,但考虑到耗材的收缩率不一样,若零件间太松可涂点胶水加固下;
  • 主图上车体的拉花是水印贴纸,需自行采购;
  • 轮胎与车轴不需要涂胶水;
Stellar Consortium | Exploration Department Standard‑Issue Prospecting Vehicle — Wild Horse‑3 Mars Rover
Matte deep‑space‑blue mech‑style body with elevated all‑terrain chassis. Fully‑electric four‑wheel drive adapted to Mars’ rugged landforms. Front mounted dozer blade for obstacle clearance and sampling. Wide deep‑tread off‑road tires withstand gravel and regolith. Dual‑layer deflecting rear wing integrated with interstellar communication array. Bound for the red wastelands, traversing the uncharted expanse of Mars.
Model Dimensions: 168×96×63 mm.
Notes:
  • Clean the build plate prior to printing.
  • This is a snap‑fit assembly model. Adhesive is generally not required. Due to variable filament shrinkage, apply a small amount of glue only to reinforce overly‑loose‑fitting parts.
  • Decals shown on the main‑render vehicle are water‑slide decals and must be purchased separately.
  • Do not apply glue between tires and axles.
火星车
车
玩具车
可动玩具
汽车
赛车
车模
Mars rover
car
PDF
组装流程.pdf
3.61MB
