玄岳 Z-001 为新一代模块化科幻中型主战坦克
隶属势力:星穹联合体 — 安全署
定位:第一代坦克实验测试车辆
- 采用标准三人乘员编制,车体尾部配置四具战术火箭助推装置,可短时爆发极限机动能力,适配战场快速穿插、战术突进与应急撤离,机动战术灵活性极强。
- 主战武器配备 125 毫米大口径制式主炮,具备优异穿甲与攻坚效能,可适配多型作战弹药,正面装甲对抗能力突出;同步搭载 12.7 毫米同轴重机枪,负责肃清前沿步兵集群及轻型机动目标。
- 炮塔火力配置层次分明,尾部集成两座四联装通用导弹发射架,可切换反坦克、防空、对地打击弹药,实现超视距精准打击;车顶搭载独立遥控无人炮塔,内置六管加特林速射武器,构建全方位近程防御体系,有效拦截低空单位、无人机及近身突击目标。
- 该车集强火力、高机动、全维度防御于一体,战术用途全面,可适配平原攻坚、山地突进、全域协防等多种作战环境,是陆上主力攻坚突击核心装甲装备。
(以上为虚构故事,仅供娱乐)
Xuan-Yue Z-001 is a new-generation modular sci-fi medium main battle tank.
Affiliation: Star Dome Union — Security Bureau
Role: First-generation experimental tank test vehicle
- It adopts a standard three-person crew configuration. Four tactical rocket boosters are mounted at the rear of the hull, delivering short-burst extreme mobility. Designed for rapid battlefield penetration, tactical assault and emergency extraction, it boasts outstanding tactical flexibility.
- Its primary armament is a 125mm standard large-caliber main gun with excellent armor-piercing and fortification-busting performance, compatible with multiple types of combat ammunition, featuring formidable frontal armor resistance. A 12.7mm coaxial heavy machine gun is fitted to eliminate forward infantry groups and light mobile targets.
- The turret features layered firepower layout. Two quadruple universal missile launchers are integrated at the turret rear, capable of switching between anti-tank, anti-air and surface-strike munitions for beyond-visual-range precision strikes. An independent remote-controlled unmanned turret is mounted on the roof, armed with a six-barrel Gatling rapid-fire weapon. It establishes an all-round close-in defense system to intercept low-altitude units, drones and close-assault targets.
- Combining heavy firepower, high mobility and omnidirectional defense, this vehicle has versatile tactical applications. It can operate in varied combat scenarios including plain assault, mountain breakthrough and full-domain joint defense, serving as a core armored asset for land-based main force assault operations.
(The above is fictional content for entertainment only.)
注意事项:
- 打印前一定一定一定要清理打印板,涂打印胶水(因为有很多细小的零件,板子不干净容易炒面);
- 本模型小零件特别多,部分零件需要用胶水固定,说明书有标明,请按照说明书组装;
- 履带采用半一体化打印,无需五金,推荐和我使用一样的PLA耗材,避免公差大;
- 第一盘都是结构件,建议采用petg耗材,当然pla也能用,只是耐久度不如petg;
Notes:
- Be sure to thoroughly clean the build plate and apply print adhesive before printing. Numerous tiny parts are included; dirty build plates will lead to warping and layer separation.
- This model contains a large number of small components. Some parts require glue for assembly, as marked in the manual. Please follow the assembly instructions.
- The tracks are semi-integrated printed parts. No metal hardware is needed. PLA filament is recommended (same as what I use) to prevent tolerance errors.
- The first plate consists entirely of structural parts. PETG filament is recommended; PLA works as well, though it is less durable than PETG.
PDF
(正常版)组装流程.pdf
14.65MB
