2026-09-29 19:52:07
525
33
玄霆H-006中程弹道导弹发射车(Ballistic Missile Launch Vehicle)
@David007_2386050
玄霆 H-006,是猛犸通用底盘家族的第六号成员,为适配中程弹道导弹的巨大重量与发射载荷,底盘升级为10×10 全轮驱动构型。
升级后的 10×10 底盘承载能力大幅提升,多组车轮分摊导弹重量,在山地、荒原、冻土等复杂地形依旧拥有优秀的越野通行能力,可隐蔽机动、快速变换发射阵地,实现机动发射,提升战场生存能力。 车体搭载一体化起竖发射筒,单车可携载一枚中程弹道导弹,具备自主测地、快速起竖、无依托发射能力,能够对敌方纵深指挥节点、军事基地等高价值目标实施远程精确打击。
驾驶室与车载电控设备做强化防护,可抵御破片冲击,车载通信与导航系统支持独立作战,无需固定阵地。 玄霆,藏雷霆于旷野,一击定纵深。
Xuanting H-006 is the sixth member of the Mammoth Universal Chassis family. To accommodate the massive weight and launch load of medium-range ballistic missiles, its chassis has been upgraded to a 10×10 all-wheel-drive configuration.
The upgraded 10×10 chassis delivers greatly enhanced load-carrying capacity. Multiple wheel sets distribute the missile’s weight, retaining outstanding cross-country mobility over rugged terrain such as mountains, wastelands and permafrost. It enables concealed maneuvering and rapid repositioning of launch sites to perform mobile launches and improve battlefield survivability.
The vehicle is fitted with an integrated erector-launch canister. A single vehicle carries one medium-range ballistic missile. It features autonomous surveying, rapid erection and non-site-dependent launch capabilities, allowing long-range precision strikes against high-value targets deep behind enemy lines including enemy command nodes and military bases.
The cab and onboard electronic control equipment feature reinforced shielding against fragment impacts. Its onboard communication and navigation systems support independent operations without relying on fixed launch sites.
Xuanting: hiding thunder in the wilderness, one strike decides the deep front.
模型尺寸:271x78x81,单位毫米。
Model Dimensions: 271 × 78 × 81 mm
注意事项:
  • 打印前请清洁打印板,涂打印胶,做好耗材烘干;
  • 本模型又许多细节零件,请注意避免丢失;
  • 模型有些零件需要用胶水固定,有些不需要用胶水固定,请按照说明书安装;
Notes:
  • Before printing, please clean the print bed, apply printing glue, and dry the filament properly.
  • This model contains many detailed parts; please take care to avoid losing them.
  • Some parts of the model require glue for fixation, while others do not. Please follow the instructions for assembly.
弹道导弹发射车
核导弹
军卡
战车
导弹发射车
军事载具
虾七八想
PDF
组装流程.pdf
10.70MB
