2025-03-09 06:59:59
1.8k
108
英国电话亭 存钱罐&灯罩(Max版)/UK Phone Booth Piggy Bank & Shade (Max Version)
英国电话亭造型,两种功能:
  • 存钱罐(第1盘)
  • 灯罩(第2盘)
特别注意:作为灯罩时耗材1(灰色)需要改为半透明PETG,以达到透光效果
最小尺寸:kobra2尺寸
此为Max版本,后续会推出MiniB版本
你需要:
  • 磁铁4mm(直径)×2mm(厚度)2颗
  • 高强度耗材(建议ABS)205mm左右
组装很简单,我就不上传组装文件了,装上磁铁,装上门,再插入耗材作为直销轴即可,有必要用502封上口子
British phone booth design with two functions:
  • Piggy bank (Disc 1)
  • Lamp shade (Disc 2)
Special note: When used as a lamp shade, consumable 1 (gray) needs to be changed to semi-transparent PETG for light transmission effect.
Minimum size: Kobra2 size
This is the Max version, and a MiniB version will be released later.
You need:
  • 4mm (diameter) × 2mm (thickness) magnets, 2 pieces
  • High-strength consumable (ABS recommended), around 205mm
Assembly is very simple, so I won't upload assembly files. Just attach the magnets, put on the door, and insert the consumable as the direct drive shaft. It’s advisable to seal the opening with 502 glue if necessary.
收纳
存钱罐
灯罩
电话亭
英国
英国电话亭
时尚
实用
磁铁
DIY
