2026-10-19 19:12:37
119
解绳游戏盘 / Untangle Puzzle Game
@User_2168597
解绳游戏盘 —— 一团乱麻,越解越上头
一套全 3D 打印的实体解绳益智桌游。绳子不用打印、不用买配件——直接用 1.75mm TPU 耗材丝,柔软韧弹、怎么折都不断。
玩法 每根 TPU 绳的两端,直接穿入盘沿骨形棋子预留的穿丝孔里,绳身相互交错,在盘心缠成一团"乱麻"。玩家观察绳子的上下穿插关系,按正确顺序把绳子一根根抽出——全部取出即通关。听起来简单?缠到 5 分钟后你就会沉默。
标准局为 11 条绳、22 颗棋子,盘沿 24 个孔位中另留 2 个「游戏活动孔位」,可临时改线、加难或自创玩法。
  • 锻炼空间思维、耐心与手眼协调
  • 单人烧脑,多人比谁更快,聚会破冰两相宜
  • 老少皆宜:小孩玩专注,大人玩解压
设计亮点
  • TPU 耗材丝直接作绳:省去打印柔性绳的麻烦,成本几乎为零,随便拿点tpu尾料就行”
  • Ø160mm 圆盘盘面:桌面尺寸刚好,盘心留白让缠绕路线一目了然
  • 骨形棋子带穿丝孔:TPU 两端一插即固定,拉扯不打滑、不脱落,可反复布题
  • 24 孔位 · 11 绳 22 棋子:标准局布满 22 个骨扣、11 条 TPU 绳,余 2 孔作「游戏活动孔位」,可临时改线、加难或自创玩法
  • 棋子四颗一组、用料极少:用打印尾料就能打,玩久了红黄蓝绿各色棋子自然凑齐
打印与材料
  • 盘面 + 棋子:PLA / PETG 均可,盘面无需支撑(棋子视机型而定)
  • 绳子:1.75mm TPU 耗材丝,剪取合适长度,两端穿入穿丝孔即可;没有 TPU 时,任意相近直径的绳子(蜡绳、棉绳等)同样可用
  • 棋子 4 颗一组打印,单组耗材极少,正好消化换色、收尾的尾料;越玩颜色越全
  • 全部零件打印时间短,边打印边就能备绳
一卷 TPU,一团乱麻,一段安静的斗智时间。祝你好运——解开它!
Untangle Puzzle Game — A Tangled Mess You Can't Put Down
A fully 3D-printable physical untangling puzzle. No rope-buying, no printing flexible parts — the "ropes" are simply 1.75mm TPU filament, soft, springy and unbreakable.
How to Play Thread each end of a TPU rope straight into the stringing holes pre-built into the bone-shaped pegs around the rim; the ropes criss-cross into one big tangle at the center. Study how the ropes weave over and under each other, then pull them out one by one in the right order — clear the board to win. Sounds easy? Wait until minute five.
A standard game uses 11 ropes and 22 pegs; of the 24 rim holes, 2 are left as "activity holes" for alternate routes, extra challenge or your own rules.
  • Trains spatial thinking, patience and hand-eye coordination
  • Solo brain-teaser or speed race with friends — a great ice-breaker
  • All ages: focus for kids, stress relief for adults
Design Highlights
  • Ropes = raw TPU filament: no flexible-filament printing headaches, near-zero cost — just grab some TPU scrap and you're set
  • Ø160mm round board: perfect desk size with an open center so every crossing stays readable
  • Bone pegs with stringing holes: push both TPU ends in and they lock — no slipping, re-set the puzzle endlessly
  • 24 holes · 11 ropes, 22 pegs: a standard game fills 22 bone pegs with 11 TPU ropes, leaving 2 holes as "activity holes" for alternate routes, extra difficulty or your own rules
  • Pegs print 4 to a set, tiny material: print them from scrap filament; play long enough and you'll collect every color
Printing & Materials
  • Board + pegs: PLA or PETG, board prints support-free (pegs depend on your printer)
  • Ropes: 1.75mm TPU filament, cut to length and push both ends into the holes. No TPU? Any similar-diameter cord (wax cord, cotton string…) works just as well
  • Pegs print 4 per set and use almost no filament — perfect for using up color-change leftovers; the more you play, the fuller your color collection
  • Short print times — prep the ropes while it prints
One spool of TPU, one tangled mess, one quiet battle of wits. Good luck — untangle it!
Puzzle
Board Game
String Puzzle
Brain Teaser
Print and Play
TPU
Scrap Filament
No Supports
解谜
解绳
益智
