2026-10-17 21:14:30
178
赛博科技-中国象棋
@MengXiaoBai_5199460
这款中国象棋你给打几分 #中国象棋 #棋中玄机 #棋局 #每日一盘象棋提升智商 #发光的棋子 - 抖音
赛博科技版中国象棋
棋盘内置棋子收纳盒,按动开关即可弹出棋子
32颗棋子内置无线感应灯,棋盘内置无线感应线圈,棋盘内部也有LED灯条,棋子可在整个棋盘内无死角点亮
棋盘和棋子内部嵌入磁铁,棋子可自动归位,棋盘立着棋子也不会掉落
棋盘内置电池,可充电使用,也可插电或充电宝使用。无线感应线圈模块配有风冷散热,可长时间使用
该棋盘为一体多色打印340*320尺寸,算上擦料塔要350*350尺寸才能完整打印 所以仅支持s1mc或k3mc机型打印,为保证整体美观,未做拆件处理(拆分打印会大大破坏美观度)
棋盘主体要使用暗色不透明材料打印。否则漏光严重
Cyber Tech Version Chinese ChessThe chessboard has a built-in storage box for pieces; press the switch and the chess pieces will pop out.The 32 chess pieces are equipped with built-in wireless induction lamps. The chessboard contains built-in wireless induction coils and internal LED light strips, enabling the pieces to light up anywhere on the board without blind spots.Magnets are embedded inside the chessboard and pieces, allowing the pieces to self-align. Pieces will not fall off even when the chessboard is placed vertically.The chessboard has a built-in rechargeable battery. It can be powered by charging, direct plug-in power supply or power bank. The wireless induction coil module is equipped with air-cooled heat dissipation for prolonged operation.This chessboard adopts integrated multi-color printing with a size of 340320. Including the purge tower, a 350350 printing area is required for full printing. Therefore, it only supports printing on the s1mc or k3mc models. To preserve overall aesthetics, it is not split into separate parts (split printing would significantly ruin the visual effect).The main chessboard body must be printed with dark opaque material; otherwise, severe light leakage will occur.
象棋
中国象棋
桌游
PDF
演示文稿1.pdf
1.16MB
