2026-03-01 14:27:00
1.6k
95
迷你停车楼(1/64)(Parking garage)
@David007_2386050
三层停车楼,是我对秩序与热爱的具象化。每一道车位线,每一根栏杆,都承载着深夜里的专注与热爱。
当超跑们依次入位,人偶在车旁驻足,这个微缩的世界,便有了自己的心跳。
This three-story parking garage is the embodiment of my pursuit of order and passion. Every parking line, every railing, carries the dedication and love I poured into it during those late nights.
As the supercars park one by one and the miniature figures stand beside them, this tiny world gains a heartbeat of its own.
模型尺寸:
  • 整体建筑尺寸:180x180x214,单位毫米;
  • 每个车位尺寸:75x34,单位毫米;
  • 每个楼层高:64,单位毫米;
  • Overall dimensions: 180 × 180 × 214 mm
  • Each parking space size: 75 × 34 mm
  • Floor height per level: 64 mm
工具:
  • 尖嘴钳;needle-nose pliers
  • 胶水;glue
  • 一条长110cm的COB灯带;(这个长度是按现成模型高度测量的,可装可不装)One COB light strip with a length of 110 cm.(This length is measured according to the finished model’s height; installation is optional.)
注意事项:
  • 图中人和车为非打印模型,需自行购买;
  • 打印前需烘干耗材,清洁打印版,涂打印胶;
  • 有些零件很小,容易丢失,请注意;
  • 请按说明书安装;
  • 如果想打印更多楼层,请将第二层的所有零件重新打印即可;
  • Before printing, dry the filament, clean the build plate, and apply printing glue.
  • Some parts are very small and easy to lose, so please be careful.
  • Please install according to the instructions.
  • If you want to print more floors, simply reprint all the parts from the second floor.
  • The figures and cars in the picture are not included in the printed model and need to be purchased separately.
Parking garage
迷你停车楼
车辆场景
微缩建筑
摆件
停车场
车库
Garage
Vehicle scene
decorative ornament
PDF
组装流程.pdf
4.72MB
