2026-10-27 13:25:43
17
钢制置物架配件 | Steel Shelf Accessory
@xiao3_4778025
>> 模型介绍 | Model Introduction >>>>>>>>
| > 灵感来源 Source of Inspiration
就单纯的想着这么的一个低碳钢置物架,除了放置东西外,周边空荡荡的,不利用起来好像有点浪费。所以就做了这个小配件来方便挂工具。
This accessory fits my low‑carbon steel storage shelf. The shelf only holds goods, and its surrounding empty space would go to waste otherwise. I made this small part to hang tools.
| > 见仁见智 Opinion varies
是否适用于其他场景,请根据模型规格自行判断。
Suitability for other scenarios is to be judged by yourself according to model specifications.
| > 模型规格 Model Specifications
● 3MF说明 Description
  ▸ ┣ 编号 ID:1030826
  ▸ ┗ 盘数 Plate Count: 2
■ 配件 Accessory
  > ┃ ┗ L70.88mm × W70.88mm × H7.30mm
  > ┣ 面板厚度 Body Thickness: 4.00mm
  > ┣ 延伸段 Extension Arm
  > ┃ ┗ L47.00mm × W30.00mm
  > ┣ 孔洞 Hole
  > ┃ ┣ 半径 Radius: 3.50mm
  > ┃ ┗ 跨距 Spacing: 30.00mm
  > ┣ 锥形凸台 Tapered boss
  > ┃ ┣ 顶面直径 Top Diameter: 9.00mm
  > ┃ ┣ 底面直径 Bottom Diameter: 7.00mm
  > ┗ ┻ 跨距 Spacing: 32.00mm
■ 挂钩 Hooks
  > ┣ 单爪 Single Prong
  > ┃ ┣ L36.41mm × W36.41mm × H57.94mm
  > ┃ ┣ 钩臂 Hook Arm
  > ┃ ┃ ┗ 半径 Radius: 2.50mm
  > ┃ ┣ 插杆 Peg Shaft
  > ┃ ┃ ┣ 半径 Radius: 2.50mm
  > ┃ ┗ ┻ 跨距 Spacing: 30.00mm
  > ┣ 双爪 Double Prong
  > ┃ ┣ L37.28mm × W37.28mm × H57.94mm
  > ┃ ┣ 钩臂 Hook Arm
  > ┃ ┃ ┗ 跨距 Spacing: 30.00mm
  > ┃ ┣ 插杆 Peg Shaft
  > ┗ ┻ ┻ 跨距 Spacing: 30.00mm
>> 组装说明 | Assembly Instructions >>>>>>>>
即打即用,无需组装。
Print-Ready / Assembly-Free​​​​​
>> 切片设置 | Slice Settings >>>>>>>>
| > 仅供参考,按需调整
For reference only; Customize as needed
| 耗材 Filament: PETG
| 层高 Layer Height
  > 层高 Layer height: 0.2mm
  > 首层层高 First layer height: 0.4mm
| 线宽 Line width
  > 首层 First layer: 0.5mm
  > 外墙 Outer wall: 0.5mm
| 接缝 Seam
  > 接缝位置 Seam position: 对齐 Aligned
| 墙生成器 Wall generator
  > 墙生成器 Wall generator: Arachne
  > 最小特征尺寸 Minimum feature size: 15%
| 墙壁和表面 Walls and surfaces
  > 墙顺序 Walls printing order: 外墙/内墙 Outer/Inner
| 墙 Walls
  > 墙层数 Wall loops: 2
| 填充 Infill
  > 稀疏填充密度 Sparse infill density: 15%
  > 稀疏填充图案 Sparse infill pattern: 网格 Grid
| 其他层速度 Other layers speed
  > 外墙 Outer wall: 60mm/s
  > 内墙 Inner wall: 120mm/s
| 悬垂速度 Overhang speed
  > 悬垂降速 Slow down for overhangs: 开 ON
  > 悬垂速度 Overhang speed: 0/25/13/5
| 支撑 Support
  > 开启支撑 Enable support: 需要 Required
  > 类型 Type: 普通 Standard (自动 Auto)
  > 样式 Style: 紧贴 Flush
  > 阈值角度 Threshold Angle: 25°
| 高级 Advanced
  > 顶部Z距离 Top Z distance: 0.18mm
  > 顶部接触面层数 Top interface layers: 4层 layers
  > 支撑/模型xy间距 Support/object xy distance: 1mm
| 筏层 Raft: 无 NONE
| 轮廓圈 Skirt
  > 轮廓圈类型 Skirt type: 组合 Combined
  > 轮廓圈数 Skirt loops: 1
>> 其他说明 | Additional Notes >>>>>>>>
1. 模型使用 Blender 5.0.1制作。
The model was created using Blender 5.0.1.
2. 可根据协议 CC BY-NC-SA 4.0 自行修改为所需样式使用。
You are free to modify it into your preferred style for your use under the CC BY-NC-SA 4.0 license.
3. 无论如何,遇见是缘分,适用是幸会。欢迎点赞或收藏,感谢关注和助力。
Still, it’s serendipity to cross paths, and a joy if this works for you. Likes, favorites, follows and support are greatly appreciated!
4. 百因必有果,打印不好别找我。即便同一设备,在不同的打印速度、切片设置、线材类型以及所处环境潮湿度都会对成品的质量、品质、效果造成影响。
Results vary by setup — I take no responsibility for failed prints. Even on the same printer, print speed, slicer settings, filament type and ambient humidity will impact the final print quality.
5. 所有成品在日常使用中都存在风险,请定期检查成品耐久,及时对成品进行更新,以免造成不必要的损失。
Risks may arise in the daily use of all finished products. Please regularly check their durability and replace or upgrade them in a timely manner to avoid unnecessary losses.
6. 鉴于模型社区的开放、包容和共享性质,为了避免引起不必要的纠纷,本人仅对 “作者” 标识的打印配置阐释说明。
Given the open, inclusive, and sharing nature of the model community, to avoid unnecessary disputes, I only provide explanations for the print configurations marked with the "Author" label.
7. 本篇英文翻译出自于豆包 AI。
This English translation was generated by DouBao AI.
>> 个人情境 | Personal Context >>>>>>>>
玩3D打印嘛,不就是缺啥打啥吗!秉持“不缺不造,不造不缺”的基本原则,贯彻“自由分享,开放共享”的开源精神,争取避免打印机躺平摆烂,吃灰摆设...🤣
Playing with 3D printing is all about printing whatever you need, right? I follow the basic principle of "no demand, no creation; no creation, no demand," and embrace the open‑source spirit of free sharing and open collaboration. My aim is to keep my printer busy instead of letting it sit idle, gather dust and turn into a shelf ornament... 🤣​
>> 声明 | Statement >>>>>>>>
1.由于个人时间和精力有限,本人仅通过个人注册的平台和账号以及个人拥有的域名(PoweredBy.CN)发布模型相关信息。其他非个人注册、授权的平台和账号发布涉及到本人制作的模型图纸均和本人无关且无任何利益关联。本人在互联网上一直秉承着“自由分享,免费共享”的理念,对已公开发布的模型图纸不会以任何理由限制下载(包含但不限于收费制、会员制、积分制等限制),请注意甄别!
2.欢迎您通过下载、点赞、关注、收藏、助力的方式表达您对模型的认可和喜爱,同时也非常感谢您对模型的点评。
3.您若同意并遵循知识共享许可协议“CC BY-NC-SA 4.0”,本人欢迎您对模型图纸以及相关页面进行任何形式的站外分享,也非常赞同和认可您对模型进行升级改造后的再分享行为。
1.Due to my limited time and energy, I only release model‑related content through my personally registered platforms, accounts and my own domain, PoweredBy.CN. Any of my model files posted on unauthorized platforms or accounts are unrelated to me, and I derive no benefits from them.
I have always upheld the principle of "free sharing and open access" online. I will not impose any download restrictions on publicly‑released model files, including but not limited to paywalls, membership locks and point‑based access requirements. Please verify the source carefully.
2.You may show your appreciation for my models by downloading, liking, following, favoriting or boosting them. I greatly value all your comments and feedback.
3.If you agree to abide by the CC BY‑NC‑SA 4.0 License, I welcome you to share the model files and associated pages externally in any form. I also fully support the re‑sharing of upgraded or remixed versions of my designs.
配件
挂钩
卡扣
Accessory
Shelf
