2026-10-05 11:30:39
280
麦沃双盘位硬盘盒排风板/MAIWO Hard drive enclosure vent baffle
@Kimmiao_2126763
麦沃3.5寸双盘位阵列机械硬盘盒DIY排风挡板,增强硬盘散热。
适配MAIWO-K35272C高性价比双3.5寸盘位硬盘盒,网上评测吐槽风扇和硬盘间的挡板无通风孔。于是手搓一块带通风孔的挡板。
注:官方已在B站实测辟谣原实心板散热有效,另外硬盘盒挡板的拆解替换请B站搜索教程,很容易拆就不详细说明了。
下期发一个2.5寸硬盘转3.5寸硬盘的模块,也可以用于此硬盘盒。
DIY air exhaust baffle for MAIWO 3.5-inch dual-bay array mechanical hard drive enclosure to improve hard drive heat dissipation. Compatible with the cost-effective MAIWO-K35272C dual 3.5-inch bay hard drive enclosure. Online reviews complained that the baffle between the fan and hard drives had no ventilation holes. Therefore, I handmade a baffle with ventilation holes. Note: The official has released actual test results on Bilibili to refute claims, confirming that the original solid plate delivers effective heat dissipation. For disassembly and replacement of the hard drive enclosure baffle, search for tutorials on Bilibili. It is easy to take apart, so no detailed explanation is provided here. In the next post, I will release a 2.5-inch hard drive to 3.5-inch hard drive adapter module, which can also be used with this hard drive enclosure.
硬盘盒
MAIWO
NAS
麦沃
