2026-10-21 15:59:58
127
🌿👀 Pot Peepers 🌿👀
@Alessio70_414990
🌿👀 Pot Peepers 🌿👀
Funny Snail Eyes for Plants
Ever feel like your houseplants are watching you? Well, now they actually are!
Pot Peepers are whimsical, snail-inspired plant stakes designed to instantly inject personality and humor into your succulents, cacti, and indoor greenery. Whether you want to turn your aloe vera into a curious alien creature or make your favorite potted plant look like a giant friendly snail, these eyes are guaranteed to spark conversations and bring smiles.
🧩 2 Versions Included:
  1. Multi-Color Version (AMS / MMU): Single-part model ready for multi-material printing.
  2. Separated Parts Version (Easy Assembly): Perfect for single-extruder printers! The components (stem/eyelid, eyeball, and pupil) are split into individual files engineered with tight tolerances for a glueless snap-fit assembly.
  3. Single Plate "Print By Object": Arrange all separated components on a single build plate and enable Print By Object mode in your slicer. The printer will finish one part completely before moving to the next, saving time and eliminating unnecessary toolhead travel or color swaps on the same layer!
🛠️ Technical Details & Print Settings
  • Multi-Color Optimized: Color transitions are arranged to keep filament purge waste to a minimum.
  • Snap-Fit Assembly: No glue required! Just print the separated components in your preferred colors and pop them together in seconds.
  • Print Orientation: Print vertically with the tip on the build plate (use a small brim for stability if needed) or horizontally with supports for a super smooth curvature.
  • Supports: Tree / Organic supports recommended under the eyeball sphere when printing vertically.
  • Infill: 15% - 20% (Gyroid or Grid).
  • Layer Height: 0.16 mm to 0.20 mm for crisp pupil detail and perfect fitting tolerances.
  • Recommended Filament: PLA for indoor pots; PETG for outdoor plant containers exposed to sunlight and soil moisture.
snail
plant
pot
vase
eyes
funny
nice
kobra
