2026-09-24 04:00:12
569
39
3-in-1 Customizable School Nameplate Parametric
@IB2M_1784411
3-in-1 Customizable Desk Nameplate & Ruler (ACE)
A smart, multi-functional desk nameplate designed for school, home, or office. It serves as a personalized nameplate, an easel stand for cards/notes, and features a built-in ruler and keychain hole.
⚡ Quick Start: Ready-to-Use Blank Bambu Studio Profile
Don't want to tweak OpenSCAD? A blank print profile (.3mf) is included!
  • Simply download the profile and open it directly in Anycubic Slicer Next.
  • Use the built-in Text Tool to add your own first and last name onto the plate.
  • Color the text layers and slice—ready to print in seconds!
✨ Main Customizable Features (OpenSCAD)
Go to my model on makerworld to online edit or download the file manually
If you prefer full parametric control, the included .scad script lets you customize:
  • Text & Typography:
  • Front primary name & optional subtitle/surname.
  • Student-facing engraved message on the back (class, grade, or quote).
  • Independent fonts, styles, and sizes for each text field.
  • Dimensions: Automatic sizing to fit your text perfectly, or set a custom fixed length, height, and slant angle.
  • Built-in Ruler: Toggle on/off; switch between Metric (cm/mm) and Imperial (inches).
  • Keychain / Bag Hole: Toggle on/off and position on the left or right side.
  • Multi-Color / ACE Export Modes: Export the complete model or split into separate STL files (Body, Primary Inlay, Subtitle) for seamless color assignment in any slicer.
🖨️ Print Orientation & Tips
  • Print Face-Down: Place the slanted front face completely flat on the print bed.
  • Benefits: This drastically reduces print time, requires no supports on the lettering, and gives a smooth, flawless surface finish to your text.
What's New in V3 (09/13/26) — Filament Saving & 3D Relief
  • Adjustable Text Thickness: Dial down text depth to 0.2 mm or 0.4 mm (1–2 layers) to drastically reduce multi-color purge waste.
  • Embossed vs. Inlay: Switch between flush lettering and raised relief text.
  • Non-AMS Glue-In Mode: Export letters flat to print them separately and glue them in.
What's New in V2 (09/09/26) — Under-Shelf & Inverted Mounting
  • 180° Text Inversion: You can now flip your text horizontally and vertically with two simple checkboxes. Enable both to mount the nameplate upside down under a shelf, desk, or monitor riser while keeping all lettering upright and fully readable.
nameplate
easel
school
sign
parametric
customizable
student
desk
office
ruler
name
keychain
organizer
classroom
ace
education
scad
kid
teacher
