2026-05-14 21:24:55
774
21
3D Printed Cyberdeck / CNC HMI
@RedKnight_4506791
This is a complete computer using a raspberry pi in a pelican case. I 3d printed all of the parts to fit inside the case to hold the electronics in place. For the brain, I used the raspberry pi 4b with 8gb ram. This is a little over the top, but I wanted the speed for my DIY CNC machine interface.
The parts are as follows:
Guidesman® 9" Watertight Protective Case - Menards - $12.99
7 Inch Touchscreen Monitor for Raspberry Pi HDMI IPS 1024 x 600 Mini LCD - Amazon - $42.99
GeeekPi Fan for Raspberry Pi 4 - Amazon - $16.99
Short USB C Cable 6 inch - Amazon - $6.99
USB Mini Keyboard - Amazon - $13.99
Micro HDMI to HDMI Cable 1FT - Amazon - $11.97
USB C HUB - Amazon - $8.99
5V-2.1A Power 18650 Holder Organizer Batteries Box for Electronic DIY Holder DIY Bank - Amazon - $13.99
18650 9900mah Rechargeable Ni-MH Batteries 8 Pack - Amazon - $24.99
2PCS RJ45 Breakout Board - Amazon - $8.29
The prices do not reflect what I originally spent on this machine, they are what the current prices are. I will link all of the specific parts below.
Basically, for assembly, all you are doing is plugging everything into the raspberry pi and glueing the ports to their specific slots. I will soon try to upload a diagram explaining all of the connections. The design is simple and easy to assemble.
Links:
Guidesman® 9" Watertight Protective Case at Menards®
Amazon.com: wisecoco 7 Inch Touchscreen Monitor for Raspberry Pi HDMI IPS 1024 x 600 Mini LCD Display for RPI Pi 5/4B/3B 2 Zero B B+ Windows Driver-Free : Electronics
Amazon.com: GeeekPi Fan for Raspberry Pi 4, Ultra Thin ICE Tower Cooler for Raspberry Pi, PWM Cooling Fan with Aluminum Heatsink for Raspberry Pi 4 Model B Only : Electronics
Amazon.com: 6 inch Short Fast Charging Cord, 5 Pack Durable USB A to USB Type C 3A Cable for Charging Station Compatible with Samsung Galaxy Note 9 10 S10 S20 S30 OnePlus 7T 8T LG V30 V40 : Electronics
Amazon.com: CUQI USB Mini Keyboard,DIY Experiment Mini Keyboard Gaming,USB Interface for Android TV Box,Windows PC,Raspberry Pi,Windows 10/8/7 : Electronics
Amazon.com: Duttek Micro HDMI to HDMI Cable 1FT/30cm, Extreme Slim Short HDMI to Micro HDMI Cable Support 18Gbps, High-Speed, 4K@60Hz, 2160p, 48-Bit Color, 3D for Sony A6500, A7,Canon Camera (Male to Male) : Electronics
Amazon.com: USB C HUB : Electronics
Amazon.com: LQMBABY 5V-2.1A Power 18650 Holder Organizer Batteries Box for Electronic DIY Holder DIY Bank Holder Case Black : Cell Phones & Accessories
Amazon.com : CBJJ 18650 9900mah Rechargeable Ni-MH Batteries 8 Pack, Flat Top 18x65mm, Perfect for Flashlights, Headlamps, Toys, Remote Controls, Bluetooth Devices & Home Lighting : ElectronicsAmazon.com: Xelsluthe 2PCS RJ45 Breakout Board, RJ45 Ethernet Female Connector Breakouts Board, 2.54mm Pitch Screw Terminal Adapter for Network Adapter Terminal : Industrial & Scientific
cyberdeck
cnc
hmi
plc
raspberry pi
diy
pelican case
computer
pc
portable
waterproof
battery powered
