2026-07-08 23:32:19
470
3D Printed Wedding Ribbon Wand
@DIYAnanas_5547944
Create a magical and joyful send-off for the happy couple with these customizable, 3D-printable wedding wands! A beautiful, mess-free alternative to throwing rice or confetti, these wands feature a textured handle, a long wand stick, and an adorable heart charm.
This project requires a mix of 3D printing and easy-to-find craft supplies, making it a perfect DIY project for weddings, parties, or celebrations.
The model includes:
The Stick: A long, sturdy hexagonal rod.
The Handle: A beautifully textured grip that the stick slides into.
The Heart Charm: A small, delicate keychain-style heart with a built-in loop for hanging.
Required Hardware (Not 3D Printed):
To complete the wedding wands as intended, you will need to pick up a few inexpensive items from your local craft or bead shop (or online). You will need:
Satin Ribbon: A spool of thin satin ribbon (typically 1/4 inch or 3/8 inch wide). White is classic, but you can match the wedding's color theme!
Mini Jingle Bells: Small metal craft bells (approx. 10mm to 15mm) to give the wand a beautiful, celebratory chime when waved.
Jump Rings (or Split Rings): Small metal jewelry rings (approx. 8mm to 10mm). You will use these to securely attach the 3D-printed heart charm and the jingle bells to the handle or the ribbon.
Assembly Instructions
Print the parts: Print the handle, stick, and heart charm. (We recommend PETG for the stick and Silk Gold PLA was used for the handle and heart charm). The stick may benefit from a higher infill or extra perimeters for rigidity).
Assemble the wand: Insert the stick into the designated hole in the top of the handle. Use a drop of superglue (CA glue) for a permanent, secure fit.
Attach the hardware: Using a pair of pliers, open a jump ring and thread it through the loop on the 3D-printed heart charm and one or two jingle bells. Attach this ring to the wand.
Tie the ribbon: Cut one or two strands of satin ribbon (about 1.5 to 2 feet long each) and tie them securely near the top of the handle.
Wave and celebrate!
prop
wedding decor
diy wedding
customizable
ribbon wand
event decor
heart charm
wedding
party favors
celebration
