2026-08-13 23:50:20
681
53
90° Angle Bracket for 60mm Timber | Hex Nut & Countersunk Versions
@mh_3DSolutions_1389014
This sturdy 90° angle bracket is designed for creating strong and precise right-angle connections between wooden beams.
It is optimized for the common 60 mm timber sizes, making it a perfect fit for many standard construction and woodworking projects.
  • Dimensions: 58 × 58 × 58 mm
  • Hole diameter: 5 mm
  • Designed for 60 mm wooden beams
  • Strong and lightweight design
  • Easy to print without supports
  • Ideal for woodworking, furniture, DIY projects, shelving, and frames
Available Versions:
Hex Nut Version
  • Designed for bolts and hex nuts.
  • The mounting surface is recessed to provide a perfect seat for a standard washer, ensuring excellent load distribution and a secure connection.
  • Ideal for strong, removable assemblies.
Countersunk Version
  • Designed for countersunk screws.
  • Countersunk holes allow the screw heads to sit flush with the bracket surface, creating a clean and professional finish.
Whether you're building shelves, workbenches, frames, or other wooden constructions, this bracket offers a reliable and professional-looking solution.
If you find this model useful, I'd really appreciate a like, download, or collection.
Happy printing!
Angle bracket
Angle
Wood
Woodworking
corner bracket
corner
corner support
frame support
diy
connector
timber
90 degree
hexnut
countersunk
