2026-08-21 03:31:11
455
12
90° Angle Bracket for 80mm Timber | Hex Nut & Countersunk Versions
@mh_3DSolutions_1389014
This sturdy 90° angle bracket is designed for creating strong and precise right-angle connections between wooden beams.
It is optimized for the common 80 mm timber sizes, making it a perfect fit for many standard construction and woodworking projects.
  • Dimensions: 80 × 80 × 80 mm
  • Hole diameter:  6 mm
  • Designed for 80 mm wooden beams
  • Strong and lightweight design
  • Easy to print without supports
  • Ideal for woodworking, furniture, DIY projects, shelving, and frames
Available Versions:
Hex Nut Version
  • Designed for bolts and hex nuts.
  • The mounting surface is recessed to provide a perfect seat for a standard washer, ensuring excellent load distribution and a secure connection.
  • Ideal for strong, removable assemblies.
Countersunk Version
  • Designed for countersunk screws.
  • Countersunk holes allow the screw heads to sit flush with the bracket surface, creating a clean and professional finish.
Whether you're building shelves, workbenches, frames, or other wooden constructions, this bracket offers a reliable and professional-looking solution.
Have a look at my other models too!
If you find this model useful, I'd really appreciate a like, download, or collection.
Happy printing!
Angle
Anglebracket
Corner
Cornerbracket
cornersupport
framesupport
timber
wood
woodworking
90degree
90°
countersunk
hexnut
