2026-03-31 03:31:06
298.1k
18.6k
AC(E)-X Filament Drybox for Kobra X
@BamBamDesign_2075164
AC(E)-X The Filament Dry Box for Kobra X
⚠️ New AC(E)-X PRO Version as Option ... scroll down for the link
The AC(E)-X is a purpose-built filament dry box designed specifically for the Anycubic Kobra X. It offers a clean, practical, and fully printable solution to protect your filament from dust and moisture!—without the need for any additional hardware.
Engineered for simplicity, the AC(E)-X requires no complicated assembly!
Every component is fully 3D printable, making it accessible and easy to produce on your own printer.
Unlike the original spool holders, this design eliminates the hassle of threading spools from the side. Simply place your filament rolls directly into the box—quick, convenient, and user-friendly.
The enclosure not only keeps your filament clean but also helps maintain dryness, improving print quality and consistency over time.
Key Features:
  • 3D printable on Anycubic X
  • Protects against dust and moisture
  • Decrease Humidity
  • Space for Desiccant Bags under the spools to keep filament dry
  • Perfect fit for the Anycubic Kobra X
  • Stable and precise mounting on the top frame
  • Clever print orientation to reduce support and increase stability
  • Lightweight – Each unit uses 450g of filament
  • Flexible setup – supports one or two dry boxes
  • Compatible with the original spool holder when using a single unit
  • Full height still usable
Designed with both functionality and aesthetics in mind, the AC(E)-X blends seamlessly with the look of your printer while enhancing its usability.
A smart, minimal, and efficient upgrade for anyone looking to improve filament storage and printing performance.
Printing:
Prints perfect in PLA+
Box Left and Right are mirrored. Plate 1 = Left & Plate 2 = Right
Lid and rollers stay the same.
Assembly:
➔ Place the 4 rollers into the Box - Grease them at the ends slightly for best performance.
➔ Slide the unit from the back over the frame
➔ Place the mounting bracket from the front. It should snap in. Screw two M3x10 from the front and one M3 from underneath to fix the position.
➔ Insert the PTFE tubes. Let them extend a few millimeters beyond the opening, then wrap them with a carefully cut piece of duct tape. This prevents the PTFE tube from accidentally slipping out.
➔ Manage the PTFE routing ---- Enjoy the compact Design
Tip: You can use a duct tape on the back to get a nice hinge ;)
Happy Printing!
The design required a significant amount of work and many large test prints. I hope the final product meets your expectations.
I really appreciate any likes, comments, and downloads of my models. If you’d like to support me further, feel free to check out my Linktree: https://linktr.ee/bambamdesign.
Thank you very much!🤝
MOD & Update Section:
Desiccant Box with Lid optimized to fit under each spool:
Hygrometer Lid to see instant the humidity in the boxes:
Ball Bearing Roller Mod for long life smoothness:
AC(E)-X Pro:
I carefully reviewed your feedback, tested new ideas, optimized countless details, and after many days of work and endless printing hours, the Pro Version is finally full optimized, tested, documented and ready for you to download. I will thank you for the support here! My Patreon subscribers will get exclusive early access to the model:
https://www.patreon.com/posts/156876582
YouTube Short
Keep in mind the Pro Version uses extra hardware, the Basic doesn't.
ACE
ACE X
Filament Drybox
drybox
filament
spool holder
kobra X
AC(E)-X
spool
functional
upgrade
ACE Pro
anycubic cobra
storage solution
filament storage
