This is a remix of "Solution for the Problem of Tangling and Poor Return of Filament in ACE PRO|纵维立方ACE PRO缠料、回料不畅问题解决方案".
I believe this will work as good or better.
New roller uses the existing bearings in the original rollers.
Tap out bearings with the roller rod.
I used a "Thwack" hammer that I printed to tap them in the new roller and used a Phillips screw driver to set them in about 1mm.
Printed in both PETG and ABS filament.
Recommend ABS if using ACE Pro for filament drying.
