2024-09-23 22:35:13
2.6k
200
Adaptive bottle cutter
@User_536_419079
Table bottle cutter
Require a cutter box blade
With this project you can cut your bottle to transform those in new pet filament
Different Section dimension
You will find some different models which allows you to chose which section dimension is right for you from 6mm to 12mm
6mm
10mm
-The long screw is for sustain the high part of the bottle when cutting(i recommend to use it or use threaded rod)
Recommended section height
bottle thickness section height
0,35mm | 6mm
0,30mm | 7mm
0,25mm | 8mm
0,20mm | 9mm
0,15mm | 10mm
0,10mm | 12mm
For any question or suggestions feel free to leave a comment or send me an e-mail at:📧 [email protected]
bottle
cutter
pet bottle
pet cutter
pet bottle cutter
table
table bottle cutter
table pet bottle
DOC
documentation bottle cutter.doc
616.50KB
