2025-03-30 00:57:30
1.5k
58
Adjustable Spinning Paint Mount/Stand
@3D_ADHD_5263124
V1 Release! So, the problem was constantly arising on how to hold my 3d prints and rotate them when i need to spray them, Simple design but WORKS!
Pin lengths are 1 inch, 3 inches and 5 inches.
Ensure your slicing settings are right so you dont get wobbly pins, if you do, adjust your X/Y compensate in slicer. Advise printing 1 off as test before doing several.
Kit includes - Base, Top Spinning Plate and Pins. Magnets can be used in the provided cutouts in base so that rotating the part is at 90 degrees each turn and also holds the spinning pin plate in place better (put them in holes next to center hole)
Base - Use 8mmx2mm magnets or smaller. I used 6mm Dia ones as thats all i had.
Spin Plate can use 10mm magnets but i just used 8mm again as they are glued in place anyway so doesnt matter and also saves hassle of print tolerances.
20% infill Adapative Cubic
0.2mm Layer Height
3d print
mask
stand
articulated
cosplay
marvel
helmet
dc
superhero
spin
spinning
tool
mount
pin
holder
adjustable
custom
136.75KB
229.57KB
52.60KB
