2026-02-18 18:52:35
680
9
Air Vent Cover
@DanyMaker_2656661
Since I needed to cover a pipe outdoors, I used ASA as the material. However, if the part is located indoors, you can easily print it in standard PLA. The object is designed to fit into 125 mm pipes; the section that slides inside the pipe (or wall) is 123 mm, leaving a bit of extra space to add a gasket if needed (I used Teflon tape, but simple silicone would work as well).
