2026-05-03 23:48:41
2.3k
91
Airbrush Paint Booth – LED, Skadis, 100mm Fan
@IlkekkoLab_4847706
A fully modular airbrush paint booth with built-in LED lighting, side pegboards for tools and paints, and a 100mm fan mount for fume extraction — everything your painting station needs in one printed build.
Painting miniatures and models indoors means three problems at once: bad light kills color accuracy, fumes need to leave the room, and your tools always end up scattered. This booth solves all three: angled diffused LED panels light the workspace evenly, a 100mm fan port pulls solvents and overspray out the back through a standard kitchen hood filter, and the side panels are pegboards that host your airbrush, brushes, paints, and mixing cups within reach.
Features:
- Three angled LED light panels (left, top, right) with diffused output for even, shadow-free lighting
- 5V COB LED strips, powered by any USB power bank — fully portable, no wall socket needed
- 100mm fan port for fume extraction (fan not included — pick your own, recommended ≥200 m³/h)
- Standard kitchen hood filter compatible — cheap, easy to replace
- Side pegboards on both flanks for tools, paints, brushes, mixing cups
- Internal workspace: 431 × 265 × 378 mm
- Includes small bed variant: split plates for printers with smaller build plates
Print settings:
- Print profile is optimized per part — each plate has its own settings tuned for that specific piece
- Material: PETG recommended (PLA works), white preferred for light diffusion
Assembly notes:
Structure is glued together with CA (super glue) — only 8x M5 × 12mm screws needed for the two Skådis pegboards. LED wiring: 3 COB strips in parallel to a push-button switch and 5V USB power bank. Fan: any 100mm inline fan fits the rear port (tested with 330 m³/h variable speed). Filter: standard kitchen hood filter cut to size. Full assembly manual (PDF) included with step-by-step photos.
Full step-by-step assembly manual (PDF) included — 10 phases with real photos, wiring diagram, BOM, CAD reference drawings, and troubleshooting guide.
airbrush
paintbooth
spraybooth
miniaturepainting
modelmaking
scalemodels
hobbystation
fumeextraction
ledlighting
skadis
ikea
pegboard
workshop
modular
organizer
painting
hobby
ilkekkolab
useful
PDF
Airbrush Paint Booth Assembly Manual .pdf
21.61MB
