2025-06-10 23:46:07
5.3k
301
Altimeter Style Desk Clock
@shivamhegadi_1438524
✈️ Altimeter Desk Clock
A desk clock styled like an aircraft altimeter — perfect for aviation fans and enthusiasts!
The numbers are arranged like a real altimeter dial, giving it an authentic cockpit feel.
⏰ Print Time: 3 Hours
🛠️ COMPATIBLE WITH
Maker's Supply Clock Kit: 011, any HR-1688 movement. Amazon
📦 Includes 3D Printed Parts:
  • Altimeter Housing
  • Altimeter Faceplate
  • Altimeter Backplate
  • Hour Hand
  • Minute Hand
  • Housing → Backplate Pins ×4
🧩 Assembly Instructions
  1. Insert the faceplate into the housing.
  2. Attach the clock mechanism through the center hole and secure it with the included nut.
  3. Gently press the hour hand and minute hand onto the clock mechanism spindle.
  4. Place the backplate onto the rear of the housing, ensuring the stand is positioned at the bottom.
  5. Insert the four housing-to-backplate pins through the backplate and into the housing.
  6. ▸ Tip: If the pins are too tight, carefully widen the holes using a pin or small drill.
  7. Rotate the clock face so it's upright and properly aligned.
✅ Done! You’ve built your own Altimeter Desk Clock!
💬 Enjoying the build?
Leave a review!
Questions or problems? DM me or drop a comment — I respond quickly!
altimeter
plane
fidget
labubu
aircraftc
clerx
anycubic
filament
spool
spool refill
makeronline
benchy
meter
mechanica
mechanical
mech
vex
robotics
robot
