2025-05-06 22:56:19
13k
1.7k
AnyCubic ACE PRO Door handle
@FlabberQuestion_1327272
This custom Anycubic ACE PRO Door Handle is a simple yet super practical upgrade for your ACE PRO enclosure. Whether your original handle broke or you just want a better grip when opening the chamber, this new handle design is an easy print and a perfect fit.
It has a smooth, ergonomic curve for better grip, and installs directly in place of the original with no additional hardware required.
Design Details:
  • Layer height: 0.12 mm (fine detail – already set in Print Profile)
  • Supports: Required (preset in file)
  • Material: PLA or PLA+
  • Only uses 9 grams of filament
Installation:
Just remove the old handle by sliding it all the way to the right and slide the new one back on
Other Prints
Check out the matching Anycubic Kobra S1 Door Handle. Who doesn't like a match?!
Check out the Kobra S1 Combo ACE Pro - Poor Man's Riser to lift your ACE PRO from your Kobra S1
Check out the IKEA KALAX Filament Spool Holder to neatly store your filament spools inside your IKEA KALLAX
ACE PRO
Anycubic
Kobra S1
Kobra S3
Door handle
Door Knob
Russ
AnyCubic ACE pro Door handle
