2026-10-24 09:16:05
505
40
Anycubic Kobra S1 - Magnetic Toolhead Cover - Flameforge
@FlameForge_3783139
Anycubic Kobra S1 — MagCover (FlameForge Edition)
"Never Let The Flame Die!"
Tired of your stock toolhead cover rattling, becoming loose, or dropping mid-print? Want a magnetic upgrade without risking your printer?
Other magnetic mods on the market are too bulky and hit the printer's frame, potentially damaging your machine.
The S1 FlameForge MagCover solves this with optimized, crash-free clearances and a rock-solid magnetic lock.
🚀 KEY FEATURES:
🧲 3-Point Magnetic Lock: Uses 3 pairs of flush-mounted neodymium magnets. Clamps down firmly with zero rattling and will never drop mid-print.
🛡️ Zero Collision (Protect Your Printer): Unlike other magnetic mods that hit the frame and can damage your printer, this cover features an optimized side chamfer that guarantees 100% smooth, collision-free movement across the entire axis.
✅ Broken Pins? It Doesn't Matter Anymore: Even if your original plastic mounting tabs are worn out, loose, or completely broken, the magnets keep the cover firmly locked in place.
🛠️ HARDWARE REQUIRED:
• 6x Neodymium Disc Magnets: 5 x 2 mm (3 for the front cover, 3 for the rear backplate). • A tiny drop of CA glue (Super Glue) to secure the magnets into the flush pockets.
• Stock 40mm fan & mounting screws from your original toolhead.
⚠️ Important Assembly Tip: Double-check the North/South polarity of the magnets before applying glue to ensure the front and rear halves attract properly!
🖨️ RECOMMENDED PRINT SETTINGS:
• Filament: PETG (recommended for heat resistance near the hotend) or PLA+ • Layer Height: 0.20 mm (Standard) • Walls / Perimeters: 3 or 4 walls for maximum stiffness
• Infill: 15% - 20% • Supports: Normal style Snug (only needed under the 3 small magnet tabs) • Print Bed: Face down on Textured PEI for a clean, matte factory finish on the FlameForge front artwork
Designed with passion under the FlameForge engineering banner.
If you like this design, please drop a Like, follow for more.
Anycubic
Kobra S1
Kobra S1 Max
Toolhead
Printhead
Magnetic
Shroud
Cover
ACE Pro
Multicolor
Upgrade
Mod
FlameForge
Zero Collision
