2026-10-09 17:57:25
1.4k
77
Anycubic Kobra S1 Max a Unique Voronoi Look
@CADria_836704
Give Your Anycubic Kobra S1 Max a Unique Voronoi Look!
Upgrade the appearance of your Anycubic Kobra S1 Max / S1 Max Combo with this custom-designed Voronoi-style print head cover.
Inspired by organic Voronoi structures, this design combines a distinctive technical aesthetic with lightweight geometry and carefully arranged openings.
KEY FEATURES
  • Voronoi-inspired design – an eye-catching, organic pattern that stands out from the original cover.
  • Print-in-Place design – designed to print as a single piece, without assembly.
  • No supports required – designed for support-free 3D printing.
  • Lightweight structure – material-saving geometry with a distinctive appearance.
  • Functional openings – designed around the fan and the cover's ventilation areas.
  • Easy customization – experiment with different filament colors to match your printer setup.
COMPATIBILITY
Designed for the Anycubic Kobra S1 Max and Kobra S1 Max Combo print head.
Please check the model dimensions and mounting geometry against your printer before installation.
PRINTING RECOMMENDATIONS
  • Material: ABS or ASA
  • Layer height: 0.16–0.20 mm
  • Supports: Not required
  • Orientation: Use the orientation provided in the model file
  • Infill and wall settings: Follow the model's geometry and your slicer's recommendations
Choose a filament color that highlights the Voronoi pattern and gives your printer a unique look.
IMPORTANT
This is a custom 3D-printed accessory, not an official Anycubic product. Verify fitment and clearance before operating the printer. Do not obstruct the fan, airflow, moving parts or safety features.
Print it. Install it. Make your Kobra S1 Max stand out.
SHARE YOUR PRINT
If this replacement helped you, please consider leaving a Like and Download.
If you print the model, please share a Make/Print photo and your feedback.
Your photos can help other users determine whether this replacement is suitable for their own bed.
Happy printing!
Support me here:
Ko-fi - Adrian M
Kobra S1 Max
S1 Max Combo
Print Head Cover
Anycubic Kobra
Anycubic
Print in Place
Upgrade
3D Printer Upgrade
Supportless
S1 Max Cover
S1 Max voronoi
voronoi
