Anycubic Kobra X Bin
This thing is an useful waste catcher that is made just for the Anycubic Kobra X. It is especially good when you are printing with a lot of colors.
When you print with a lot of colors the Anycubic Kobra X makes a lot of lines and little bits of waste. This basket is meant to sit to the Anycubic Kobra X so all the extra stuff falls into it. This keeps your workspace clean and tidy.
- The design is simple. It works well
- It is made to catch the waste that comes out when you print with a lot of colors
- The top of the basket is open so you can easily pick up the waste
- It is light. Does not take long to print
- The sides have a texture that makes it look nicer and work better
Use Case
Put the basket where the Anycubic Kobra X throws away the extra filament. It will catch the lines and blobs by itself. This means you will not have a mess on your desk or floor.
Printing Tips
You do not need any help to print this
It is best to print with layers that are 0.2 mm high
The Anycubic Kobra X Waste Catcher Basket works well with PLA, PETG or similar things
You only need to fill it up a little 10 to 20 percent is enough, for the Anycubic Kobra X Waste Catcher Basket
