2026-10-20 03:55:04
153
Argemone ear cuff
@TheMatterBureau_3869887
Ideal for Halloween costumes, festivals and photoshoots. I recommend sizing one side first, then mirroring it in the slicer to print both sides.
Sizing reference:
  • Ear width at the top: 3.5 cm
This is my personal measurement for reference. Fit may vary depending on your ear shape and the specific design.
Adjusting the Fit with Heat:
If necessary, you can carefully reshape the cuff using a hairdryer:
  3. Once the plastic becomes bendy but is not melting, carefully adjust its shape.
  4. Hold the new shape until it cools and hardens completely.
Heat warning: Hot plastic can cause burns. Never put a warm cuff on your ear. Allow it to cool completely before wearing it, avoid overheating, and work in a well-ventilated area. Adjust gradually and ensure the cuff does not pinch or cause discomfort.
Repairing Broken Parts:
ear cuff
halloween
forest fairy
botanical prop
wearable
