2025-06-19 19:31:31
5.7k
297
Armadillo Modular truck - 1/18 scale
@Polymech3D_2784684
This is a 1/18 scale (rc scale) modular truck. It can be printed as an display piece or as an body for the 1/18 scale Traxxas TRX-4M RC chassis.
A BOM and detailed assembly guide is available here:
https://docs.google.com/presentation/d/1jDFZVQZJTaoTreNDtWG9hZRczSIi7os__GL_CBwH4Bk/edit?usp=sharing
The model is modular so you can spec out your truck in several ways, with different cabin looks + there are some submodules that can be added to change its appearance. There are different bed variation to choose from as well.
The model is quite heavy, depending on what modules you put on it, compared to the stock bodies that comes with the TRX4M so you most likely need stiffer than stock springs at the front.
Model Features
Two different cabin looks, military style and a flat roof version
Different submodules and bed variations to choose from
4x4 and 6x6 chassis support
The storage shelves boxes/tanks can be swapped out and custom ones be made. They are snap on parats held with magnets.
Lights can be installed in the front and rear bumpers. The body is easily detached from the chassis so you can reach the battery/motor/server etc.
A display stand for the body is available. Includes printable tires and rims. The stand is compatible with both the TRX4M Armadillo and Catmaw editions. The front/rear bumpers from respective cars are mounted to the stand and then the body can be mounted by sliding the body on top.
4x4
6x6
rc
car
truck
off-road
military
modular
scale model
