2024-04-22 21:10:08
16.8k
2.4k
Articulated Minecraft Creeper: Print-In-Place
@Delphant_4556386
  • From the best-selling video game Minecraft!
  • Print-In-Place and fully articulated.
  • Optional face pieces included.
  • Designed in Fusion 360.
  • UPDATE 3/28/2024:
  • Fixed model orientation.
  • Made Head stronger.
  • Default Head rotation +90 deg for single extruder filament swap for new extruded face option (FACE_EXT ver).
  • Modified how built-in supports work, this should allow for easier removal (NO_SUP ver).
  • Added a version that needs support for a better overhang on the upper legs (SUP ver).
Printing:
  • NOTE: This model was designed with a .4mm nozzle in mind, other sized nozzles may not work. Scale at your own risk.
  • Printed at .2mm layer height with 20% gyroid infill and 3 walls.
  • Use the default orientation.
  • FOR Creeper_NO_SUP and Creeper_NO_SUP_FACE_EXT
  • Supports are not required, this version will have worse overhangs.
  • DO NOT repair the model; doing so will remove the custom supports, causing the legs to print fully in mid-air.
  • Turn off Detect Overhang Walls.
  • FOR Creeper_SUP and Creeper_SUP_FACE_EXT
  • Print using supports.
  • Only needed under floating legs, paint-fill overhang.
  • Tree and Snug work well.
Clean Up:
  • After printing, the head and legs should snap apart, allowing them to rotate freely.
  • Be careful not to apply too much pressure when releasing the joints.
  • You can also print the optional Creeper face and use super glue to adhere the pieces (for Creeper_NO_SUP and Creeper_SUP).
Design Iterations
creeper
minecraft
pip
3dprint
printinplace
minecraftcreeper
mc
