2026-08-30 18:20:31
227
Auxiliary Pool Ladder Stabilizer Bracket (50mm - 44mm tube clamp)
@Kracko1__964009
We bought a plastic step ladder to make it easier and safer for my mother to get into the pool. However, being lightweight, it moved around a lot with the water flow, which was unstable and a bit scary.
To fix this, I designed this 3D model. It is a double clamp specifically designed for 50mm and 44mm tubes respectively, which firmly attaches the new PVC/plastic ladder tube to the existing stainless steel pool ladder.
Desconocido
Now the auxiliary ladder is completely anchored and wobble-free. A great safety upgrade!
🔩 Hardware required:
  • Hex bolts and nuts (Stainless steel highly recommended to prevent rust in the pool water).
⚙️ Print Settings:
  • Material: PETG, ASA, or ABS are recommended for UV and chemical (chlorine) resistance.
  • Infill: 40% - 60% (Gyroid or Cubic) for mechanical strength.
  • Walls: 4 to 5 perimeters for maximum rigidity.
  • Orientation: Print flat on the build plate for optimal strength along the tension axis.
