2026-09-12 22:04:01
289
BIG OWl hueforge
@PrintCube3d_2064362
Print at 100% infill with a layer height of 0.08mm with a base layer of 0.16mm
 The Model is 200x200mm in size
 You may print at higher layer heights below the Base Thickness of 0.48mm
 The Max allowed Thickness is 2.24mm and the Actual Thickness is 1.67998mm
#080a0d PLA Anycubic Black Transmission Distance: 0.3
#e2dedb PLA Anycubic White Transmission Distance: 5
This print uses 2 unique filaments
Swap Instructions:
Start with Black
At layer #9 (0.84mm) swap to White for the rest.
big
owl
hueforge´
hueforge
mocho
desenho
coruja
art
flexi
