2026-09-11 20:37:11
341
12
BOT-07 — Articulated Robot
@Timmy1293_5232336
Meet BOT-07, a fully articulated and 37 cm tall robot designed specifically for 3D printing.
This is not just a static figure. BOT-07 features multiple articulated joints, allowing you to pose the robot in a variety of positions. The joints are designed and tested specifically for 3D printing, with tolerances tuned for PLA so that the assembled robot remains stable while still being poseable.
⚙️ FeaturesFully articulated body
Articulated head
Articulated shoulders
Moving elbows
Articulated torso
Articulated hips
Articulated knees
Articulated ankles
Designed for easy assembly
No screws, magnets or external hardware required
Optimized for FDM 3D printing
Tested with PLA
Designed as a modular platform for future hand/tool attachments
🦾 Modular hands
The included hand is the basic BOT-07 claw.
The wrist is designed as a modular connection, allowing different hands, tools and attachments to be developed in the future.
Recommended material: PLA
Layer height: 0.2 mm
Supports: I printed every part without supports, but for safety I add some supports to the print profile.
Infill: 8%
Walls: 2
Individual parts are provided separately for easier printing and assembly.
🔧 Assembly
The robot uses press-fit / snap-fit connections and printed pins and some parts you need to glue it.
Because PLA joints can loosen slightly after repeated movement, the joints are intentionally designed with sufficient interference to provide a firm fit after assembly.
Tip: Test the joint before fully assembling the robot. Printing conditions and filament can affect the final fit.
BOT-07 is completely free to download.
If you print one, I'd love to see it! Feel free to share your build and tag me.
More modular attachments are planned. 🦾
