2026-10-25 17:51:39
122
14
Balancing Black Cat Sculpture (Easy Removal Supports)
@Kris_4543489
This is an optimized print profile for the Kitties 3D figure! Massive thanks to the original creator @Ah_3d for this amazing design.
I have fine-tuned tree supports and slicer parameters so that supports snap off effortlessly without leaving marks or damaging the detailed surface. Tested and printed clean!
Key Features & Print Parameters:
Easy-to-Remove Tree Supports: Custom top Z-distance (0.22mm) and 4 concentric interface layers for effortless support detachment.
Layer Height: 0.20mm
Infill: 15%
Nozzle Temp: 220°C | Bed Temp: 60°C
Estimated Print Time: ~1h 19m
Material Consumption: ~21.2g
Model Size: 42mm × 99mm × 70mm
cat
Balancing
statue
decor
easy-supports
tree-support
pla
Black Cat
animal
stairs
