2026-09-25 00:12:07
302
Balfix bar holder
@3DRF_GR_2579937
I made this little holder to solve a simple problem with my pull-up bar.
After using a tension-mounted pull-up bar for a while, it can sometimes get a little loose. I wanted something that would help keep the ends of the bar in place and prevent them from slipping out of position, so I designed this holder.
The holder mounts directly to the door frame with two screws, and the end of the bar sits inside it. The raised edge around the holder helps keep the bar in position even if the tension becomes a little loose.
It's a small and simple print, doesn't use much filament, and you only need two holders — one for each side of the bar.
Just make sure the size of the holder works with your bar before printing.
I hope you find it useful! If you print it, feel free to share your Make. 🙂
balfix
pullup
barholder
holder
bar
doorframe
doorway
mount
support
bracket
fitness
gym
homegym
workout
exercise
safety
stabilizer
accessory
wallmount
