2026-04-29 02:19:12
517
Bambu Lab AMS HT - Skadis Mount - Hook Version
@wiste95_4538938
This is a remix of damole19's excellent BambuLab AMS HT IKEA SKADIS Mount with T-Clip. Big thanks to damole19 for sharing the original model and making this remix possible!
The original design uses T-clips that you insert into slots and rotate to lock. However, on my Bambu Lab P2S with a riser, the top only has oval slots and no open space at the back — making it physically impossible to rotate the T-clips into position. So I had no choice but to redesign the mounting mechanism entirely.
What changed: The slot + T-clip system has been replaced with hooks. You simply slide the mount into the SKÅDIS board and thats it!
Compatibility:
  • Bambu Lab AMS HT
  • IKEA SKÅDIS pegboard
  • Tested on Bambu Lab P2S with riser (oval slots only / no rear clearance)
  • Should also work on setups where T-clips are accessible, as a simpler alternative
Print settings:
  • Material: PETG
  • Wall loops: 5
  • Sparse infill density: 20% (Gyroid)
  • Supports: Yes — required for hooks
This is my P2S-Riser.
If this mount saved you the same headache it saved me, consider leaving a like, adding it to your collections, or sharing a make — it helps a lot! 🙏
ikea
pegboard
skadis
filamentdryer
ikeaskadis
p2s
bambu
skadismount
hookmount
bambulab
amsht
bambulabriser
amshot
