2026-10-05 01:06:59
611
12
Bed Lift Handles – TPU Replacement for Slatted Bed Frame
@CADria_836704
A strong and flexible 3D-printable replacement handle for lifting a double bed slatted frame.
The original handles on my bed frame were made from a soft rubber-like material and eventually broke after several years of everyday use.
I designed this replacement handle using TPU for ACE / TPU 68D, providing a combination of flexibility, toughness and mechanical strength suitable for repeated lifting of the bed frame.
The geometry was designed around a comfortable grip and secure two-screw mounting. The reinforced construction is intended to withstand repeated loading while retaining a certain degree of flexibility.
The model is designed to be printed flat on the build plate, without supports.
Recommended print settings
Material: TPU for ACE / TPU 68D
Layer height: 0.20 mm
Walls: 15–20 minimum
Infill: 30–50%
Top layers: 8–10
Bottom layers: 8–10
Supports: Not required
Print orientation: Flat on the build plate
Why so many walls?
The handle is a functional load-bearing part, not a decorative object. The high wall count significantly increases the amount of solid material around the load-bearing geometry and mounting area.
For this reason, I recommend 15–20 walls minimum, especially if the handle will be used frequently or with a heavier mattress.
The infill can be adjusted between 30–50% depending on the required strength and printing time.
Highlights
  • Designed for TPU for ACE / TPU 68D
  • Strong yet flexible
  • Reinforced construction
  • Comfortable ergonomic grip
  • Two-point screw mounting
  • No supports required
  • Prints flat on the build plate
  • Designed for repeated everyday use
  • Ideal replacement for broken or deteriorated original handles
Important
Print the handle flat on the build plate as shown in the model orientation.
For maximum durability, use the recommended 15–20+ walls rather than simply increasing infill. This keeps the critical structural areas much more robust while preserving the benefits of TPU.
SHARE YOUR PRINT
If this replacement helped you, please consider leaving a Like and Download.
If you print the model, please share a Make/Print photo and your feedback.
Your photos can help other users determine whether this replacement is suitable for their own bed.
Happy printing!
Support me here:
Ko-fi - Adrian M
bed handle
bed lift handle
bed frame
furniture repair
3D printable
flexible TPU
functional print
replacement part
DYI
furniture accessory
Anycubic
TPU for ACE
TPU 68D
TPU
Kobra S1 Max
Kobra S1
