This bedside phone charging pocket is designed to keep your phone safe, accessible, and charging while you sleep.
It mounts next to the bed and holds your phone securely, preventing it from falling on the floor or getting lost under the pillow.
The model features:
- a bottom opening for the charging cable
- a side hook to organize and hang the charging cord
- a compact pocket design suitable for most modern smartphones
The holder is optimized for phones with a width between 70–85 mm.
If your phone is wider or narrower, simply scale the model in your slicer to adjust the size.
Designed for easy printing without supports.
Internal Dimensions
- Width: 85 mm
- Depth: 15 mm
- Height: 80 mm
Mounting Options
- High-quality double-sided tape
- Screws (mounting holes included)
Mounting hole specification:
- Screw diameter: 4 mm
- Head diameter: 8 mm
- Countersunk (conical) head
