2025-05-01 16:46:32
8.4k
755
Bellmouth Fan Inlet for Kobra S1
@rozsmix1_371876
Hola Guys,
Quickly I modeled a Bellmouth inlet type fan inlet.
The Idea came from turbochargers, and Intakes, often it is used to optimise the inlet airflow to get better performance, so i tought that we can help the Kobra fan also to suck air easier and on a more smooth way.
TBH I dont know if this is going to make a big difference, in paper it should have some positive effect, if not its not restricting the airflow at least, and looks like a Turbo inlet if you are a Car enthusiast. :D
For print settings i suggest to make trials with the XY Contour compensation the get the best fitting for your printer.
For assembly just pop into its place and its done. :)
Thanks, and hopefully its going to help you and make your printer looks "cooler" a little bit. :)
Br.: Győző
#kobra
#S1
#Fan
#Optimalisation
#cooling
