2024-04-22 21:37:41
5.8k
639
Berserk: Behelit
@Delphant_4556386
Berserk: Behelit
  • Griffith's Egg of the King.
  • From the best-selling manga Berserk, by Kentaro Miura.
  • I remixed this model from robopillow on Thingiverse to be easier to 3D print.
  • I recreated the top cap piece to be more durable.
Printing:
  • All files are oriented in the way they should be printed.
  • The cap part is oriented like that so the loop is as strong as possible.
  • Printed with 15-20% gyroid infill at a .2mm layer height.
  • Supports are only necessary on the cap part.
  • Recommend printing with a .15mm layer height.
Assembly:
  • After removing any supports, make sure the parts fit together.
  • The puck part goes between the top and bottom Behelit parts.
  • The cap part might have a tight fit, sanding may be necessary.
  • Use superglue to bond the parts in place.
  • Superglue may not be needed for the cap if the fit is snug.
Please let me know if anything does not fit properly, or if you have any suggestions.
behelit
berserk
guts
dark
fantasy
charm
anime
manga
egg
griffith
casca
prop
cosplay
king
