2026-10-04 05:41:35
176
18
Big Multi battery dispenser 20AA + 20AAA
@TomiksCuprou_3610084
Gravity-Fed Battery Dispenser (20x AA & 20x AAA)
This is an extended version of the popular Multi Battery Dispenser. It is designed for those who need to store a larger cache of batteries while maintaining a slim, functional profile. This dispenser holds 20 AA batteries and 20 AAA batteries simultaneously.
How it works:
The batteries are stacked horizontally. Thanks to the internal angled tracks, gravity does all the work—when you take one battery from the bottom slot, the rest slide down automatically, ensuring you always have a battery ready at your fingertips.
Print Settings:
This model has been optimized for easy printing without the need for complex setups.
  • Orientation: Print lying flat on its side (as oriented in the STL).
  • Supports: No supports required.
  • Layer Height: 0.28 mm (works perfectly and saves time), but 0.2 mm also works great for a smoother finish.
  • Infill: 10-15%
  • Material: PLA, PETG, or ASA.
Key Features:
  • High Capacity: 20 of each common type (AA/AAA).
  • Print-and-Go: No assembly or post-processing needed.
  • Visual Check: Easily see how many batteries you have left through the front openings.
battery
batteryholder
batterycover
batterycase
batteries
batterydispenser
