A sleek, cosmic Black Hole Lamp creating a realistic gravitational lensing effect. To build it, you only need an LED Lamp Kit 001, some super glue, and two filaments (black + white or translucent).
Assembly
- Stick the LED puck inside the housing using its included adhesive pad.
- Route the USB cable through the opening in the back.
- Test-fit the parts, apply a few drops of glue, and hold firmly until set.
Print Profile & Settings
The provided .3MF file is 100% pre-configured and ready to print in roughly 8 hours with no multi-material system needed (No ACE / AMS required, fully compatible with Anycubic Kobra X and standard beds).
If slicing raw STLs:
- LightFront & LightBack: White or translucent, 100% infill.
- BlackParts: Black, 100% infill, supports enabled.
- Stand: 3 wall loops, 15% infill.
Remix & Credits
This model is an improved remix based on the work of NAM_3. The geometry and print profiles have been fine-tuned for Anycubic printers and single-extruder setups. It is shared under the exact same license as the original design.
https://www.printables.com/model/1817533-black-hole-lamp
