I have an avid reader wife. Me, not being a reader, designed this sign for my wife as a birthday gift. I figured I would share it with everyone on Maker spaces so your significant other or family member that likes to read can also keep a counter.
The print was printed on a H2D but can be adopted to any printer with at least a 130mm cubed build volume. I sliced mine for the following:
.20 mm Balanced Strength
Changed the infill type to Gyroid
Base - Layer 26 swapped to copper silk
Numbers - Layer 11 swapped to copper silk
That was all the tweaking I did. And in total it took about 5.5 hours to print. I did a dry fit on everything (I glued to hooks on so I could lay them down while printing for better strength.
If you have any suggestion, please message me and I will implement the change.
