2024-10-19 00:05:33
4.1k
513
Bottle opener three sizes
@vkobz_1020444
I came across this great bottle opener, but I wanted the handles to be wider and easier to print. This device works on a good range of bottle cap sizes. PETG is recommended since it will flex and return to its original shape after use.
PRINT SETTINGS
PETG preferred (let me know how it turns out if you try PLA or any other material)
Supports will be needed on the flat overhang.
Print with the wider more open side on top.
5 walls, 15% infill
outer walls first
avoid putting the seam in the teeth, ideally placed at the end of a handle
bottle
cap
opener
twist
accessibility
assistive
device
disability
aid
