2026-03-07 07:31:34
1.1k
25
Bread Bait Press – DIY Fishing Bait Maker
@User_826224
Turn ordinary bread into effective, long-lasting fishing bait with this manual press. Designed for what Czech anglers call "rohlíkové boilies" (bread boilies), this tool lets you create custom bait balls that absorb flavors and stay on the hook.
⚠️ READ THE INSTRUCTIONS FIRST ⚠️
This model has important assembly and usage details. Please read all instructions before printing or using.
What Is Bread Bait?
Steamed bread is pressed into small balls, typically pierced with a needle and looped onto the hook. These "bread boilies" are then soaked in liquid attractants (boosters) to create irresistible bait. Natural oil or glycerin helps the bait hold together underwater. Sweet solutions also improve durability and appeal.
The Process:
  1. Steam bread in microwave or steamer until soft
  2. Place in plastic bag
  3. Press using this tool
  4. Break/Shape into small pieces
  5. Thread with looped line using a needle
  6. Boost by dipping in your favorite attractant
  7. Dry until ready
  8. Fish!
Features:
  • Adjustable Clamp: The tension arm can be repositioned for more efficient pressing—find the leverage that works for you.
  • Screw Mechanism: Provides controlled, even pressure
  • Simple Design: Few parts, easy to clean
🔧 IMPORTANT ASSEMBLY NOTES 🔧
  • LUBRICATION IS MANDATORY: Apply oil to the screw threads and contact surfaces before use. Vegetable oil works in a pinch, but SOMETHING must be used. The mechanism WILL NOT function properly without lubrication.
  • Print the screw without brim to ensure clean threads
  • Supports needed only for the clamp (see photos)
Print Settings:
  • Material: PETG or ABS/ASA recommended
  • Brim: Not necessary (except avoid on screw)
  • Supports: for clamp only
  • Infill: 20–40%
Need a Different Size?
Do you want larger or smaller bait balls? Message me with your desired dimensions, and I'll create a custom version!
🚀 Make Your Own Custom Bait!
👉 DOWNLOAD and start experimenting with homemade boilies.
❤️ LIKE if you enjoy DIY fishing solutions.
🔄 SHARE your bait recipes and catch photos!
⭐ RATE the design to help other anglers find it.
https://youtu.be/UbOqR3Xu8vs
fishing
bait
boilies
press
