2026-02-08 01:08:23
1.1k
34
Cable Clip V2
@MouseManYT_1141442
This is V2 of my original cable clip, designed to neatly hold cables together.
--- IMPROVEMENTS ---
This version uses a compliant hinge rather than a standard hinge, reducing the tolerances required for printing and allowing you to use imperfect prints as you would a perfect one, even if they warp!
The clip piece is also much stronger on this model, meaning you can bulk up more cables before it opens or breaks!
You can also scale up the model to fit your own size requirements. I have tested the model at various sizes, from 75% scale up to 150% scale, and they work perfectly.
--- PRINT RECOMMENDATIONS ---
The model can easily detach from the print bed, so it is recommended to add a small burr at the ends of the clip and the hinge portion, as shown in my print profiles.
The model was tested in PLA and PLA+, but for long-term use, PETG may perform better if you plan to undo the clip often.
Cable
Clip
Cable Clip
Cable holder
Cord
Cord Clip
Cord Holder
Organiser
Cable Organiser
Cord Organiser
