Cable Wall Grommet – 10 mm Wall Thickness
This 3D printed cable protection grommet is designed to safely guide a cable through a wall or panel, protecting it from sharp edges and excessive bending. It provides a clean and secure pass-through solution for cable management.
The design is intended for:
- Wall thickness: 10 mm
- Required hole diameter: 10 mm
- Cable diameter: up to 7 mm
Once installed, the grommet helps reduce strain on the cable, prevents abrasion, and improves the overall appearance of the installation. It is ideal for desks, furniture panels, thin walls, or DIY setups where cables need to pass through safely.
The smooth, rounded geometry ensures gentle cable routing while keeping the cable firmly in place.
Key features
- Protects cables from sharp edges
- Clean and minimal pass-through design
- Easy press-fit installation
- Suitable for desks, walls, and panels
This model is a simple and practical solution for neat and safe cable management in everyday setups.
